Another NO BUS truck. It's challenging me... LOL
Hello, I have a 2002 Dodge 2500, 5.9L 24V Cummins that’s been down for months & so far is stumping me. It has Auto trans, 4WD, & about 190k miles. As far as I know it’s all stock except for a FASS DDRP fuel pump. This is a long one, but any help or suggestions would be greatly appreciated!
Truck was running fine & then died. Cranks (spins good), but no start. First thing noticed was fuel pump not running. Then also saw gauges are not working, no wait to start light, & odometer flashes a few times then displays “NO BUS”. It will connect but not communicate with a scan tool. It either displays no communication from module or circuit open (from the airbag module). The OBDII scanner adapter lights up & I have Ign + & ground at the connector.
That of course lead me on a CCD communication path for troubleshooting. I started by disconnecting each module or component, 1 at a time, in the CCD circuit. Got it down to only ECM, PCM, & cluster connected- no change. Went ahead & removed the cluster & still no start. While removing I inspected each connector for damaged terminals, corrosion, or dirt. They all looked good.
I then checked the CCD wiring- for short to each other (the Bus + & Bus - pairs), short to ground on each wire, & short to Ign + on each. No shorts or incorrect continuity found on any of that. I also continuity tested each CCD terminal to all the other connector terminals for each wire. Every terminal has continuity with all others on each of the wire pairs.
I then started checking all the grounds, battery +, & Ign + wires to the ECM, PCM & OBD II connectors, Every one of those tested well (even load testing them). I have also checked all fuses (good).
At some point in there I self-tested the cluster. Every light & gauges seems to function properly. At the end I get 920, 921, & 999 errors in the odometer display. Seems to point to PCM problem…
I have checked battery grounds to body & other points. All OK. I haven’t dug into doing a W-T ground wire mod, but doesn’t SEEM to be an issue with that either. Maybe I’m wrong though?…
There is a ground wire to the block just above the starter & according to wiring diagrams, it grounds the fuel pump, fuel heater, A/C compressor clutch, & the CAN-BUS ground. The wire terminal seems good & 3 of the 4 connectors have good continuity to ground. I haven’t found the Cummins Can-Bus connector to check that. Diagrams show it’s located on front left of engine & has 3 terminals ( Bus +, Bus -, & ground). I’m unsure of where or how to check that….
I pulled the PCM & sent it off for bench test & repair. It was returned saying nothing wrong with it. Next I sent out the ECM. They found some corroded terminals & repaired solder connections. I was hopeful that their findings were the issue, but no change after reinstalling so doesn’t seem to be either of those.
Next I went digging deeper in the CCD system. I’ve gone through some flow charts that don’t seem to show any issues. I’ve read multiple threads on here about CCD & saw posted that you need 2.49- 2.51v on each of the CCD wires to ground. I have 2.45v on each of them. I have a troubleshooting flowchart from Mitchell ProDemand that says I need 1.8v to 2.3v. So I guess I’m in range, but can’t say 100% either.
Swapped PCM with a good running 2001 Cummins 2500, AT, 4WD. Both trucks functioned the same way as before even with a different PCM. This truck still had flashing odometer & NO BUS with the ’01 PCM. The other truck ran fine on the ’02 PCM. So that tells me the PCM in this truck is probably fine.
The only thing that I can think of is to either swap the cluster (but I don’t really think that will do anything) or go back through all my wiring & fuses again in case I missed something. Or I am very open to suggestions if you have thoughts on this? Thanks for any help. I greatly appreciate it.
Edited by 4x4 Nut
  • Replies 16
  • Views 2.8k
  • 4x4 Nut
    4x4 Nut
    Well I finally figured it out & got the truck repaired. After inspecting the ASD circuit & relay & finding all OK (which goes directly to & from the PCM), I rechecked the power & g
  • Tractorman
    Tractorman
    I won't be able to offer any help - I am responding because you haven't received a response yet and I didn't want you to think you were being ignored. From reading your post it seems that you have
    CANBus was left for the "Cummins Insite" tool for the diagnostic connector. 2003 The CANBus was introduced to the 3rd Gens. We are just in the testing stage of this with the VP44 communications.
From reading your post it seems that you have been very thorough in trying to get your issue resolved. You have checked everything that I can think of that needs to be checked.
Maybe @Mopar1973Man will respond now that I have flagged him. He is knowledgeable in this area.
  • John
Sorry been on the road limited cell service.
My suggestion at this point I would consider contacting Auto Computer Specialist and have the PCM and ECM tested. Something is wrong if the wait to start does light up, fuel pump not bumping at key on. Then the PCM creates the CCD bus so. Wiring on the CCD would need to be checked for sure. Bias voltage is not correct even after removing modules.
No worries. Thanks for replying! Do you know where the "Cummins Bus" component is located? It's listed in the wiring diagrams with 3 wires to it. It's the only item I haven't been able to get my hands on so far. It's located in the bottom & towards the right in the diagram below. Says front left of engine, but I don't see anything.
I was quite prepared to have the PCM looked at again, but then earlier this week I swapped that with one from the good running '01 & it made no change- This '02 truck didn't work any better with the '01 PCM & the '02 truck ran fine on the '01 PCM. So I'm thinking the PCM has to be working OK. Maybe it's time I recheck continuity on the CCD pair & all the ground & + wires to ECM & PCM.... 🤷‍♂️
CANBus is right near the ECM typically used for tuner connection. Wire map above covers both the CANBus and CCD bus. CANBus is used for the VP44 injection pump and tuner data.
Thanks. So is that just a wire connector that's not plugged into anything then? Allowing a tuner to connect directly to the ECM vs the OBDII port?
Update! Hello all, I finally made significant progress on the '02 Cummins with NO BUS message & crank/ no start. I've found that the Auto Shut Down relay is not being activated. I jumped the power to load terminal where the relay fits into the Power Distribution Center & things in the dash began to function correctly- all the gauges were working, the wait to start light worked, & no more NO BUS message is displayed in the odometer. The fuel pump is also working as normal. I had to bleed the injector lines & crank on it a bit, but it now runs again.
I still have to find why the ASD relay isn't being powered & repair, but I at least know WHERE the problem is coming from. Thanks for your help guys!
Another update & today's puzzler.
I had the truck running with a jumper wire at the ASD terminals (between the battery & load terminals) which I was very happy to hear it run & find the area the problem is from. While going through different things with it I had the relay back in at one point & it functioned properly (dash lights good & no error). So I wondered about a faulty connection and/ or wire. I lifted the Power Distribution Center (PDC) & removed the lower cover to see if any corrosion or faulty wires underneath. Also looked at the big square harness connector that connects to the PDC. Everything looks good. I put the PDC back in place along with the harness connector. Then I tested continuity between the 2 ASD relay terminals that connect to the PCM- 1 is the trigger for the relay & the other sends power to PCM. Both circuits were good. So I put it all back together & checked the relay itself. It functions OK & has continuity between the switched terminals. So with that everything SEEMED OK. I used a pick & tightened the ASD terminal openings in the PDC just in case there was a bad connection to the relay. I checked another relay also (also worked fine) & just swapped it with the ASD spot. Put everything back together, hopeful that it was working, & unfortunately the same problem- gauges aren't working & NO BUS error in odometer. So, I jumpered the ASD terminals again & this time the cluster works fine, but it won't fire.
I then retested the ASD terminals. Both the battery slots have voltage. I don't get a ground on control wire from the PCM though like I should. Until I jumper the battery & load wires. Then I get a ground signal from the PCM. That doesn't make sense because I'd think the PCM has to first signal the relay to work before the relay can send power, but it's not triggering the ASD until it's jumpered.
Any thoughts are welcome. Thanks
Edited by 4x4 Nut
Engine System (Page 1) wiring map 1999 Dodge Ram
Double-check the PCM socket for any damage or corrosion. Which should be pin 85 of the relay. The PCM controls the ground to Pin 85. Then pin 86 gets ignition power to energize the relay. If you do not have a ground signal, then the PCM would need to be sent in to be rebuilt. I would send it off to Auto Computer Specialists in Florida. Here shortly, I'll be sending Thor's ECM to get the exhaust brake circuit fixed.
The PCM connector & pins are nice & clean. I have good continuity between pin 85 at the ASD & pin 3 on C3 of the PCM. And also good continuity between ASD pin 87 & PCM pin 12 on C3.
Mine is a little different than the diagram you have posted. On mine, the ASD pin 86 gets battery constant power just the same as pin 30. Both get power through the PDC joint connector #2, which is just a terminal jumper in the PDC.
I'd also suspect a PCM fault, but I had sent that out for testing & repairs a few months ago. It was returned with no problems found. Not saying they couldn't have made a mistake or something happened since then, but I'm hesitant to think the PCM is faulty....
Here's a diagram of what I have. Thanks!
Edited by 4x4 Nut
  • 5 weeks later...
Well I finally figured it out & got the truck repaired. After inspecting the ASD circuit & relay & finding all OK (which goes directly to & from the PCM), I rechecked the power & ground circuits to the PCM. I did not have voltage at the battery + connector pin. Traced that back to joint connector 2 in the PDC & then on to the 20 amp J-Case #3 fuse. Keep in mind, I checked these wires to the PCM previously & had voltage at that battery + pin. I found that the fuse was not burnt from overload, but cracked & intermittently working. It even looked fine through the top clear cover. I pulled it to check closely & with a DVM to check continuity. It would beep off & on when I wiggle the leads around. That's how & when I found the crack. I installed a new fuse, reconnected everything, & it's working great now. Have a good day fellas.
Edited by 4x4 Nut
Glade you found the problem. It's the simple problem that that makes a thing hard. I've had a fuse do the same thing years ago, it to drove me crazy.
You have done some incredible troubleshooting! And such a simple, inexpensive solution! You came here asking for help, buy you ended up providing the help.
Thank you for posting the details of your solution. Your thread will be an inspiration for others to be diligent and methodical when diagnosing difficult symptoms.
@Mopar1973Man , could you save this thread in a place for easy access for anyone to read? It is an excellent read for anyone to illustrate the importance of methodical troubleshooting. It could be titled something like, "Why Methodical Symptom Diagnoses is so Important" - followed by an introduction from you.
  • John
Edited by Tractorman
I can leave it right here and let you author out an article on the website. I'll give you a $10 credit on your account for article production. You create, edit, and modify anytime you wish.
I am leaving for two weeks (camping and fishing with a friend) to the Grand Mesa in Colorado. I will consider putting together an article when I return. All of the area on the map below is right at 10,000 feet elevation.
  • John
Should try a trip to Seven Devils, Idaho too but you have to walk to all the lakes.
