new stuff installed
well..the truck is grid heater deleted...a FBD grid heater delete was installed.....and a black power coated ats arc flow intake.....i got a block heater and a high/3cyl. box ..so no problems.i like it so far.:thumbup2::thumbup2::thumbup2::thumbup2::thumbup2::thumbup2::thumbup2::thumbup2::thumbup2:
  • Replies 12
  • Views 3k
Nice, you'll have to let us know how it changes the performance.
no..and i even thought about it while i was installing them.Posted ImageandPosted Image:thumbup2::thumbup2:
i like it and don't have to watch the voltmeter and listen to the heater pull down the amps and such...Richard Martin(owner of Glacier Diesel Power) told me that when removing the grid heater..you take the main wire harness off and toss 'em BUT MAKE SURE THAT YOU LEAVE THE 2 LITTLE WIRES HOOKED UP TO THE SOLENOIDS BECAUSE THE ECM NEEDS TO SEE THAT IN ORDER TO NOT THROW ANY CODES!!NICE FELLA AND VERY KNOWLEADGEABLE!!so you remove the little ground wire that is on the front of grid heater..the two on the back of the grid heater and follow them down to the solenoid on the driver side down by the battery and remove the 2 THAT COME FROM THE GRID HEATER!!oh and when it is cold like it has been the last two days here in INDY..i turn the key to run..the :wts:comes on for a few seconds...go off...start the truck and NO VOLTAGE DROP..NO LIGHTS DIMMING NOTHING!!!now need a different turbo and a ats or pdi exhaust manifold...oh and still new to get them new rv275's installed!:thumbup2::thumbup2::thumbup2:
I want one !!! nice :thumbup2:
i run the smarty on #8..t.m.#1.....timing on #2....and the duration on#1....and the edge juice w/att. on #2(which is tow) and the low end responsiveness on highest..so that is 2x5 on you folkses drag boxes...and the new installed items are sweet...very very touchy throttle...and very responsive..even with factory turbo,exhaust manifold,and stock injectors...you'll like if ya get that stuff..the ats arc flow has 5 ports for boost,water/meth,n.o.s.,propane,and the come with 5 pipe plugs to plug 'em if you need to!!:thumbup2::thumbup2::thumbup2:
How much for ats arc flow ?
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
sorry truck is dirty...what else ya wanna see?
i got a new replacement phone..can ya tell..i can't put the camera down!!!:lmao:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image:thumbup2::thumbup2::thumbup2::thumbup2:
why is that doing that?i previewed every pic after submitting it and now that i am done.they are not showing up:banghead::banghead::banghead::banghead::banghead::banghead:
there they are.....:hyper::thumbup2:
don't see them again..what is up???????????????
Posted Image
need to get these 6 items in!!:thumbup2:
