- Replies 9
- Views 3.1k
ISX 2 posts
AH64ID 2 posts
stodg73 2 posts
Mopar1973Man 1 post
Sorry for the beginner question but I'm not having a lot of luck with the search feature. I'd like to install some gauges - fuel pressure, boost, & EGT. I understand best accuracy is achieved by selecting a gauge where the engine's normal operating range is in the middle of the gauge's range. But I don't know what is the engine's normal operating range for boost & EGT ('99 3500 2wd auto 4.10). The truck is stock now but I may boost things later for MPGs & towing an RV. Next mod after the gauges will be a decent aftermarket lift pump (100gph).As I recall, before the Turbo is where the probe should be installed. On my first gen that required drilling & tapping the manifold - does the same apply on the 24 valve?Appreciate the help,Joe in St Louis
