- Replies 12
- Views 3.8k
ISX 3 posts
white01 3 posts
Mopar1973Man 2 posts
jlwelding 2 posts
I just adjusted the valves on my new head for the first time and noticed all the rockers hold oil. Before it would about 3-4 rockers would hold oil and the rest would be empty.My thought was they should leak down if they had good flow. But all rockers held oil thru the entire valve adj.These are the original rockers on the same pedalstal's.The only diff. I can think of is all new valve springs, would that cause them to hold oil if the springs where holding more pressure?Hey Mike new pump from chip came in yesterday, took long enough.lol I sure didnt wont to go thru the explanation of the clear line again.lmaoMerry Xmas
