- Replies 29
- Views 7.4k
Mopar1973Man 12 posts
98whitelightnin 10 posts
Heavyd1980 3 posts
C Holmes 2 posts
I went to the dealer and had them activate high idle but it doesnt work. I used a 56k ohm resistor that Prowelder sent for testing purposes and the water temp was down around 100 degrees. I believe the resistor is doing its job at fooling the truck into thinking that its 32 degrees outside because the grid heater took along time to go out in 60 degree weather. MY ultra-gauge shows me that my tps reads 0.00 for the most part but every now and then it will jump up to 0.39 for a few seconds so im thinking this could be the problem. I have a Timbo apps thats only about a year old and I never really could get all the readings to line up like Tim told me to but he said it really didnt matter if it didnt have a delay in throttle responce. Question is, what do I adjust and how do I adjust it?
