Posi Lock Cable
Ok guys my question is who is running or had experience with these http://www.4x4posi-lok.com/app_dodge.html??? If you are running one whats the install like, op's like, what does the install look like in the cab, etc.? for the price it doesnt look too bad but i would like to hear from you guys.
  • Replies 55
  • Views 11.7k
well the final install doesnt look horrible, i wonder what the rest of the install is like (their website only shows the install on a Chevy) and the operation of the system.
The install is fairly simple, to be honest. You're changing the fork hat from vacuum to cable operation (obviously), and there's no other real tricky parts involved.
well i was kinda curious about the op's in cold weather? Do you have any experience with these Rogan?
I've put them on Jeeps. They seem to work just fine; it isn't a real issue, AFAIK.the other nice think is, you can use it as a 2L transfer case option.. Engaging 4L, but not the front axle.. ;)
that is a great point 2L in real 2 wheel drive would be nice!!! thanks man.
yeah, it makes it kinda nice when you need that slow, low gear, but on hard surface (like backing up a big trailer, etc.)
I've never put one in but knew a rancher with one that the shop I worked for installed and my old boss said it wasn't hard to do. Pretty handy to have I think, I'd like to have one so I would have 2L for trailers and such.:thumb1:
thanks Winslow. i just used my 4by the other night with the snow and all and i wasnt real sure that it was in 4by. so i thought about all the wonderful vacuum lines to run down.
well thats what i was concerned about every time i have engaged the 4by i have never seen the light!:doh:
my 4wd light is inop, but I know when it's engaged, by the steering
and see i've thought about that as well, but im still pretty new to this truck and this is the first winter i've had it so im still learning the truck.
ok i will give that a shot when the snow goes away. thanks Winslow
well ive had it in 4by on the dry pavement but it was always in a straight line.
it won't take much steering input to know, on the dry.
