Ok guys my question is who is running or had experience with these http://www.4x4posi-lok.com/app_dodge.html??? If you are running one whats the install like, op's like, what does the install look like in the cab, etc.? for the price it doesnt look too bad but i would like to hear from you guys.
  • Replies 55
  • Views 11.4k
BJY thats a pretty good setup! are you still running this? And also correct me if I'm wrong but if i run the 1100 kit that makes my axle the same as the 02 models right?
I haven't run that setup, but I'm going to be because the other day I found out that my CAD doesn't lock-in any more so I'm going to be doing that setup here when I get the chance. I guess it would seem like it would make it like an 02 axle but I'm not sure. I'll have to go out and figure out a way to lock my axle in and see what it does without the transfer case in 4wd.
Well I took the articulator/CAD cover off and locked my axle in and tested it somewhat. In 4wd it bucked quite a bit which was expected, In 2wd it seemed like maybe there was a little binding getting close to full lock but I can't really be sure because the driveway is pretty icy and I couldn't take it out on the road because the power company is working out there and has our drive blocked in for now.
well i will let you guys know i am going to order the 1100 kit hopefully early next week since its snowed twice now in a week. and this is the cheaper route for me to take right now. when i get it in I will take some pics of the kit and the install.
OK an update to this post I was completely committed to purchasing this kit but I got a couple of free hours this morning and went out to the ol pick and started jacking with it. What I found was the NV271 tcase that I am running has the vacuum switch out of the original 241 case in it. I am certain that either the switch is bad or the 271 does not have the internals to make contact with the switch. So i bypassed the vacuum switch and I now have 4WD. So I'm going to run it this way at least until spring when I can actually get under the truck without snow on the ground and fix it properly.
At least you figured out the problem man. Kinda strange that someone swapped in a NV271 though!:ahhh:
i've heard of several folks doin this swap because the 271 is a stronger tcase but you never hear about the vacuum switch side of the swap.:cookoo:
People always seem to leave out the fine details!!:lmao2:
yes i think what i would like to do is find a 2 way toggle switch and just plumb it into the cab so i can activate the cad then shift the tcase. if you know of anything i could use let me know. thanks Winslow.
i was kinda wondering that myself
It seems like you could b/c it cuts off the vacuum supply to the CAD unit just like it needs to on the NV271. So my guess would be yes, however, there might be a better/cheaper way to do it.:spend:
  • 3 weeks later...
I put a posi lok on a 99 that I used to have, To clear a few questions up, No there will be absolutely no bind from leaving the axle engaged as long as your in 2wd with the transfercase, don't matter if you are on dry pavement. 2nd thing I will say is it was super nice for the lo 2wd option for backing campers or whatever into a tight spot, that was the only reason I did it. 1 big downfall for me (us) was that we lived on a mile of dirt (no gravel) and when it rained or snowed my wife would usually drive the Dodge and she would always fight the posi lock to get it engaged or sometimes disengaged. I would sometimes just stop and back up or even turn side to side, kind of like the old 81 chevys with the auto locking hubs, it was just bound up and wouldnt always shift in/out real easy, then the next time no problem at all. It didn't bother me at all but trying to explain to her what was happening was a no go. I think it is a good setup, just not real user friendly for people unfamiliar with them.
