- Replies 12
- Views 6.9k
Heavyd1980 5 posts
Mopar1973Man 2 posts
tylerkck 2 posts
dracozny 1 post
My 2002 HO cummins had a catch can off the oil breather on the front of the engine. I was sick of forgetting to empty it, then dripping all over my driveway, or spilling when changing. I just extending the hose down past my axle. It coated everything down stream of it with crud, but it seemed to work (only dripped a little). Last summer I nearly overheated when towing and I'm blaming the problem on oil vapor getting sucked into the radiator (I read this happens with the stock setup). I've looked at the different options available to get rid of the crankcase vapor and I want to try an evacuation system. I like this because the vapors stay vapors and exit with the exhaust, no drip, no catch can to drain. Also, the vacuum on the crankcase increases with load/rpm.
Crankcase Evacuation.docx
