HX35 wastegate control - overboosting issue
- Replies 11
- Views 9.1k
mr.mindless 4 posts
ISX 2 posts
AH64ID 2 posts
Mopar1973Man 1 post
Before I mucked around under the hood, I used to get 33psi with my 12v reliably and repeatably. Never spiked, never buried the gauge as long as the boost line was hooked up to the wastegate control.
I've now swapped in a P-pumped 24v and I'm overboosting at and near WOT when under load.
I only have a 35psi gauge and it'll pin it - probably getting to 45+psi. Stock gasket and retorqued stock bolts to 130# with roughly 17˚ effective timing; I can't boost that far safely. I'd like to be back to 30ish psi peak boost. I'm still giving manifold pressure to the wastegate, and I actually just stepped up line size from 1/4" to 5/16" but it didn't make a difference.
What I changed:
- nothing at all on the turbo side. same turbo, same wastegate actuator, nothing dropped nothing adjusted nothing intentionally tweaked...
- the boost line is now about 2' longer since it needs to run around the one piece valve cover instead of between #3 and #4.
- manifold pressure source and routing changed.
before:
1/8" NPT port in head to boost gauge
1/8" NPT port in head to tee, unrestricted to 1/4" line to wastegate; restricted port to AFC
now:
1/4" NPT port in intake horn to 5/16" line to wastegate
1/8" NPT port in intake horn to tee, unrestricted to boost gauge and to AFC
One other difference is I have lost smoke - it used to smoke badly off the line until 1300-1400, and now it does not at all, but timing is at least a little different now.... I didn't open the AFC during the swap so star wheel, idle screw and fuel plate (#100 home ground) settings should all match. Only difference should be 1-2˚_timing. It now acts exactly as it should with a well tuned AFC: no smoke off the line, and it doesn't start to overfuel until about 2500rpm and WOT. I think I actually need to move my fuel plate back a little as it'll get hot up there, but I need to get the overboost taken care of before I can tune the top end.
How can I restrict my boost?
