OPTI-LUBE Summer Blend
- Replies 13
- Views 7.2k
Mopar1973Man 5 posts
capj 5 posts
dorkweed 1 post
jhmiller 1 post
Have any of you guys tried the Opti-Lube Summer Blend ?
It is ranked # 4 in "The Test".
I have been using 2-cycle exclusively for many, many, many miles now. :thumbsup [Thanks Mike & Dorkweed]
But I got to studying the chart again and it finally dawned on my 'old' mind that the Opti-Lube Summer Blend would actually be cheaper to use and actually showed better results than the 2 cycle.
I do realize the two cycle was tested at a 200:1 ratio, while I use a 128:1 ratio.
The Opti-Lube at a 3000:1 ratio would be much cheeper than the 2 cycle at a 128:1 ratio..
What do you guys think ?
Any down side to using it instead of 2 cycle??
Please be honest, you ain't gonna hurt my feelings......... LOL
