- Replies 13
- Views 3.3k
fire176969 5 posts
jonathan1950 4 posts
cumminspower 1 post
JOHNFAK 1 post
Well I was changing the fluid and filter in my wonderful stock 47re yesterday.
Found what looked like a 5 inch diameter snap-ring in pieces attached to the magnet in the trans pan. Had a good bit of metal shavings on the magnet also. Trans is also slipping when it shifts gears now with the fluid lever full. Worked fine until changing the fluid and filter. Anyone ever run into this? Has anyone ever used Revmax parts for their trans?
