Speedometer pegged out and tranny stuck in high gear.
- Replies 7
- Views 3.5k
LKuilder 3 posts
dually 2 posts
Mopar1973Man 1 post
fire176969 1 post
I was on my way to church this morning and my speedometer started acting up going to like 127 mph for a few seconds at a time. That is all it was doing. I went to leave church and head to the shop and more problems... As soon as I turned the key on the speedometer instantly pegged out again. The truck started fine and when I went to leave its like the convertor was stuck in lockup and the tranny is in high gear.I can put the shifter down into 1 or 2 and the tranny will shift into those gears but the speedometer remains pegged out and anytime the speedometer is pegged out and you put the shifter in D the tranny stays in high gear. I'm thinking possibly the VSS on the rear end? Any suggestions/tips would be GREATLY appreciated.
