- Replies 8
- Views 2.5k
Mopar1973Man 2 posts
dorkweed 2 posts
ISX 2 posts
AH64ID 2 posts
I want to do more testing on my truck to see how things work. I did the valve thing so we know where they are at at both TDC's but that is one of the many things we don't know about these trucks. Another thing I want to do is measure how long the pump is pushing fuel. It won't be perfectly accurate since I have to do it unpressurized so part of the fuel that is under the pop pressure will not make it out the injector but it should give us a rough idea. I know there are a hundred other interesting things about our trucks that would be neat to know but I wondered if you guys had any specifics. Maybe even something we already know but another way of proving it. It can be anything from a mechanical part, an electrical part, even just a bolt. I am planning on getting pics of every single connector on the truck for reference as well. I gotta get my truck done by this week so then I will finally be able to finish some other things I wanted to do, like making a very fancy thing showing where the valves and pistons are and the stroke they are on all based upon 0-720* rotation (since it takes that much to do all 4 strokes per piston). Don't hold back any ideas!
