- Replies 25
- Views 19.8k
bjytech 9 posts
MnTom 5 posts
ISX 5 posts
Mopar1973Man 2 posts
I'll start this out by saying that the other week I installed gauges (Boost and EGT). I was told that for my truck with whats done to it I should be able to make 35psi boost easy but the most I've seen is 28psi and that was accelerating up a hill giving it all its got in 4th gear. So I decided to check for boost leaks. Tonight I did a pressure check at 6psi and all the intercooler boots and everything seemed fine. Then I noticed the oil dipstick was hissing a little so I take it out and the air is somehow leaking in and coming out there. Would this happen because I did the pressure check wrong? Are you supposed to block off the one end of the intake when you check it? Is this happening simply because intake valves are open? Or could there be some other cause?I may sound a bit stupid... but hey, there's no stupid question right?
A guys gotta learn sometime.All your advice will be much appreciated!Also one more thing if anyone knows. On the gauge there is an orange wire for the dimmer, but the instructions don't tell you what to hook it up to for it to work. So if anyone could tell me where to hook it up to that would be great.Kinda a long post but hopefully everything is clear for you guys, if not just ask what you want to know.
