Stumped, lose power brakes /hard pedal after prolonged application?
- Replies 8
- Views 3.2k
Mopar1973Man 3 posts
Wild and Free 2 posts
jlwelding 1 post
mr.mindless 1 post
Brake system on my 02 4x4 was not opened up, problem started a few weeks ago after replacing both front hub assemblies. Just pressed brake pistons in and left them hang. Before starting it I pumped the brakes a few times to get the pistons filled and pushed back out. now ever since I loose my power brakeing after about 2-3 applications or prolonged applications like rolling to a stop sign ect. The pedal gets rock hard and there is a grinding noise almost like air in the system and a pump is cavitating sort of like the abs pump is acting funny. I have bled the brakes and get no air and the power steering is operating well and level is good. Brakes work excellent otherwise, not week or spongy ect but only does this after what I describe above. What am I missing. No brake light or abs lights on. I replaced the right hand abs brake cable as that one was ground up when the bearing failed but I reused the left one and shimmed it as it came on the new bearing, it was getting loose but hadn't failed yet. Don't think this is the issue as I would have an abs light I would suspect if it wasn't reading wheel speed correctly. Short stops or 1-2 short applications there are no issues everything works perfect. Anymore use then it acts up. No leaks anywhere either. I have had many issues over the years but this one has me stumped. Anyone ever run into this?
