- Replies 10
- Views 4k
cummins2k 5 posts
Mopar1973Man 2 posts
MnTom 1 post
jlwelding 1 post
About a week ago my wife went to drive my truck and it wouldn't start. It cranked but didn't even try to fire. Oddly the lift pump (airdog 150) ran when the key was first switched on but not after cranking like it always has. Also weird wad the lack of any attempt to fire. A few minutes later I tried again and it fired right up. Today after getting tires it did it again the techs had to push it out of the shop. Once again after about 15 mins of messing around it fired. Same symptoms. Now's its fine again. The truck runs fine once started, no codes, and its runs 14-15psi of fuel pressure. Reading about the internet I see the asd relay being a potential issue. I hear this supplies power to not only the lift pump but also the injection pump. Does any one have any information about this relay? I am baffled as to why the airdog turns on when the key is first switched on but not after it has been cranked.
