Will not start sometimes... Lack of power sometimes...
- Replies 5
- Views 2.5k
MnTom 1 post
mrtowman4u 1 post
MarbleCrusher 1 post
dchanceafs 1 post
I have 2001 Dodge Ram with cummings engine. Has the following symptoms
[*]Sometimes you get in and turn key and it will turn over and over and never hits a lick, but if you turn key off and try again it cranks right up.
[*]Sometimes you get in and it cranks the first try
[*]Does not matter if it's hot or cold
[*]Sometimes it seems to be slugish (as in it will slow down on a hill and if you step on it, keeps slowing down), the next drive is just fine all the power you need.
I have done the following
[*]New fuel filter
[*]Checked pressure and it's 21 PSI at idle, using the test location at the injector pump
[*]Not sure about the following, it only pumps when cranking, should it pre-pump when you turn the key on? or does the pump only run when starting?
[*]Soon as you turn key off, pressure QUICKLY (2-3 seconds) drops to 0, should it not hold pressure for a while after it has pumped up?
Any suggestions?
