Why you never mix and match injector parts...
- Replies 5
- Views 2.6k
Mopar1973Man 2 posts
jlwelding 1 post
MarbleCrusher 1 post
IBMobile 1 post
Well I finally got around to cleaning up my RV275 injectors again...
I've always had a random misfire problem with them at idle, only when hot. Finally got bad enough that I couldn't deal with it any more. I yanked them out and stuck in my stock injectors. In the mean time, I went out and bought a digital caliper for the tool box. So I figured I would pull them apart and measure the pintle needle, copper washer thickness, and spring shim.Kind of shocked at a few injectors...
[TABLE=align: center][TR][TD]Copper Shim (Inch)[/TD][TD]Pintle thick end (Inch)[/TD][TD]Pintle thin end (Inch)[/TD][TD]Spring Shim (Inch)[/TD][/TR][TR][TD]0.0545[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0755[/TD][/TR][TR][TD]0.0525[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0690[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1570[/TD][TD]0.1270[/TD][TD]0.0630[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1570[/TD][TD]0.1265[/TD][TD]0.0710[/TD][/TR][TR][TD]0.0535[/TD][TD]0.1520[/TD][TD]0.1215[/TD][TD]0.0675[/TD][/TR][TR][TD]0.0540[/TD][TD]0.1570[/TD][TD]0.1265[/TD][TD]0.0675[/TD][/TR][/TABLE] Now #5 in the list has a strange sized pintle and nozzle. I verified the ID of the nozzle bore and the OD of the pintle and its a true fit of both. But looking at the part and how exact they must be to work properly, I went back through and cleaned them all and reassembled all 6 injectors. Then installed them in the truck and Man talk about a change. I was really really picky about them this time and actually checked all the measurements and made sure all the pintles and nozzles were spotless. So I'm back to running the RV275 injectors...
