Can OBD-II scanner and tuners unable to connect
- Replies 21
- Views 16.9k
cltdba 10 posts
rotory26 6 posts
x50v 2 posts
Mopar1973Man 1 post
- 2007 Dodge Ram 2500 5.9L CTD- Superchips Cortex 3950 - Innova Can ODB-II 3100e scanner Tuner was working fine before a trip to the dealership. I had a problem where my wait to start light was coming on at highway speeds. Also threw P1222. All of this happened after tuning truck with superchips cortex tuner. (I had the tuner left over from my previous gas truck, thought I'd see what it could do.) So I put the truck back to stock and took it to the dealer for repair. Dealer installed 6 new injectors. I still had the WTS light problem, but was able to use my code scanner to check DTCs. That's how I found the P1222. Hooked up a friends fancy Matco scanner and it was unable to connect the truck. After that, I could no longer connect my Innova scanner either. I thought it was just fluke and took it to the dealer to fix the P1222 and WTS light.Dealer replaced FCA and PRV which in turn fixed my WTS/P1222 problem. After getting the truck back, I attempted to connect my programmer to the truck. It came up with error saying it couldn't detect ignition on. I then tried my Innova scanner and it said it was unable to connect to the vehicle. I then tried the programmer in a friends Jeep and it was able to connect and tune it with no issue.I took the truck back to the dealer for this new problem. They were unable to find any problem and said the issue was with my scanner. (Didn't tell them about programmer.) I then asked them to try reflashing the truck. They stated after the injector change that I already had the latest software, but I wanted to see if they would run into errors like I did. They did not have any problems flashing the truck with their DRB3 tool. I actually went back with them and watched them do it. I then went to a local diesel shop who was so very kind to open a brand new Smarty JR and see if it would connect. It didn't throw errors, but also could not connect. It kept going through the key on/off cycle. After about 5 tries we gave up. Just this past weekend, I ran into a friend with the new Smarty SSR. I had him attempt to connect to my truck and it also did the exact same thing.Does anyone have any idea what this might be? I'm thinking bad ECM and am prepared to replace it, but I don't want spend the cash and that not be the problem. So far, Superchips, Innova and MADS haven't been able to confirm what might be wrong. MADS suggested a bad ECM. (On another note, I'm extremely impressed with MADS customer service considering I haven't even bought their product yet. If I can get this truck working I will be purchasing one asap. Already have my Quadzilla Scout II which interfaces with the smartys.)
