Intake question, sucking air in somewhere?
Do the bolts that hold the rear engine lifting bracket on the head go through the intake housing and do they need thread sealer on them?Reason I ask is I just installed the scheid 100 hp injectors and was test driving and looking for leaks and when I spray things down with brake cleaner It is pulling it into the intake when I spray around the # 5-6 injector line/lifting bracket area.Intake cover and manifold area are ok but it is the area behind it that causes it to start sputtering when I hit it with brake cleaner, only thing I could think is if it was following the lifting braket bolts into the intake?Any ideas?
  • Replies 8
  • Views 1.9k
I'm going to guess you might have a manifold gasket leak...I don't think the hoist bolt hole is open to the manifold... Because don't a lot of people just throw the hoist ring?
My 01 is soild, and I threw it away. Now you got me wondering. I will spray right now. Be right back.
Went and took the bolt out of mine and it's straight through, not part of the intake. Not the same as a 24V I suppose but the intakes end in the same spot :shrug:
Well shoot, I guess now I need to replace the gasket for the intake cover.:banghead:Now that I got it all back together.:banghead:
Verify it with a boost tester... :shrug:
I figure If it can pull brake cleaner in it will leak pressure out.
