Are they greaseable or not ?
- Replies 15
- Views 4k
AH64ID 5 posts
anoldbiker 4 posts
jlwelding 3 posts
Wild and Free 2 posts
I have looked over the front driveshaft u-joint each time I changed the oil and have yet to find where to grease it. Because of taking the time to look each time I change oil, it takes an hour to do this. I need help. I have read through this site, other sites and have spent enough time reading on this topic, it’s like spending months in a library. One pic shows where to grease (I borrowed from another site), and the other is my front joint. There is a major difference. a) On the older style joint there are retaining clips holding the caps on.b) There are NO retaining clips holding the caps in on mine, but little pins through the side. There is no hole for greasing anywhere on this u-joint or yoke. Is there a u-joint that you do not grease ? My owners’ manual states grease EVERY oil change. I’m so %*#^&*!# confused.
