New purchase, TONS of questions/problems to fix.
- Replies 6
- Views 3.6k
Mopar1973Man 2 posts
Rogan 2 posts
thedsmguy 1 post
bjytech 1 post
Where to start.. Well, its been quite a while since I've been on this site, I'm happy to see its going well!Just purchased another cummins after missing my 98 after selling it a year or so ago.This is a 91 d250 2wd automatic.#1 After driving it for a couple hundred miles with wandering steering the truck suddenly started shaking as if I had a flat tire. Well, I do not. I suspect its likely in the front end. I jacked up the wheels and there is a small amount of play in the bearings but not enought that I think this is the source of the shaking.#2 Excessive blowby. Is there anything I can do to keep from smoking out the cars beside me at a stoplight? Or is the motor just to worn out?#3 Is it a 3 speed or Overdrive tranny? I'm only getting 3 gears. Is there a simple check to see which trans I have, The truck will do 55 on the freeway 60 is ok but over that is working it a little.#4 NONE of the gauges work, no speedo, odo, charge, fuel level, nothing. Any suggestions on why everything would be out?#5 Windshield wipers are only working on high mode. (I suspect a combo switch, but let me know if I'm wrong)Until I get these things figured out I'm not going to worry about much else, there are a handfull of smaller questions I have for the truck.Thanks a ton! Paul
