rear end
Can anyone tell me if the rear end in an 01 1 ton requires friction modifier? Thanks
  • Replies 5
  • Views 2.1k
Yes. Look at the glove box tag,it should say. you can also call any dealer with your vin number and they will tell you how your truck was built.
yes it will. all the 1 ton.s come with limited slip so anytime the diff oil is changed it will need some
