Pulling the trigger on a few mods soon.
- Replies 9
- Views 2.3k
pepsi71ocean 3 posts
Gunsablazin 3 posts
ISX 1 post
thracing 1 post
Hello everybody, I am about to purchase a bunch of stuff for my truck and I wanted to make sure that I had all of my bases covered. I've done a ton of searching and I'd like to thank everyone for everything they've contributed to this site. It's an awesome source for doing research!I've got an 01 QCSB 4x4 CTD, Auto, 3.55, 160k, and it's my daily driver when I'm not on my motorcycle. I had to replace the exhaust when I got it and other than that it's pretty much stock. I've got a 4" Diamond Eye from the turbo back. My main goal is reliability, though power may come later. Here's the stuff that I am going to buy in the near future. If I've left anything out then please let me know!In the very near future I'm going to get:BHAFISSPRO Gauges from Vulcan - Mechanical boost, fuel pressure, and EGT. Possibly a tranny gauge (it does a good bit of slipping).Big line filter to injection pump w/ fuel pressure access. Shortly following this I will get some sort of lift pump, probably an AD150, and an iQuad. I'm more interested in the MPG gains, turbo timer, and reliability features of the iQuad for now, but the power benefits will be good later.I figure that I will run the fuel right to the gauge using the needle valve like suggested here, and I plan on keeping my stock fuel filter housing. Would I benefit from getting my fuel pressure reading from the big line kit, or from another area? Also, is the snubber a must have if i am not running the isolator?Next is in relation to the drawstraw. I don't recall seeing a lift pump on the block, but I could be wrong. I see so much info on draw straws that I don't understand what I need, or if the AD150 will come with everything else I need.I suppose my final question is in relation to mounting the AD150. I like how MoparMan has his mounted and from what I gather there isn't a shortbed mount like that made anymore. Would I have any problems with the fuel lines if I decided to make my own bracket and mount my pump in that location (near the transfer case). It's my understanding that the lines are premade with the fittings already installed so there aren't many options for relocating it without getting new lines. If this is a false assumption then let me know, and if the FASS doesn't have this problem perhaps I will go that way.Thanks. I look forward to installing some stuff in the future!
