weird road noise and clanging
- Replies 7
- Views 4.2k
Rogan 2 posts
mr.mindless 2 posts
KATOOM 1 post
hawkeye213 1 post
Alright you have the normal road noise ( tires on the pavement )the last week or so I have what I can only describe as the same road noise but it is just louder. It sounds like it is coming from the front center of the truck As you accelerate it gets louder. I finally got the boat out for the first time this year and pulled it to the lake. The ramp is unbelievably steep so I just put it in 4wd to drive up the hill. As I am going up the hill I hear what I think is the safety chain bouncing up and hitting the frame of the trailer. I go fishing and then put the boat back on the trailer put it in 4wd and start to hear the clanging again Get up to the top of ramp and realize it's my truck making the noise. I take it out of 4wd and it stops. Put it back in 4wd and turn the wheel and slow rate of speed and the clanging seems to get worse. I looked at all the U joints and checked all my fluids and everything looks alright. As I drove home from the lake I was thinking the loud road noise and the clanging in four wheel drive must be connected. It doesn't make any noise when turning the steering wheel in 2wd. The steering is tight and straight down the road. I used the 4wd earlier in the winter and had no problem. Any thoughts on where to start ? Maybe a u-joint going bad ?Thanks Rob
