An uncertain noise...
Alright, so as the weather continues to get warmer, I find myself with the window down more and more. As nit picky as I'am I seem to get myself well-attuned to things when I use it or operate it enough.Well, as it may have it, my eagle ears picked up a paculiar noise. Performance wise, I do not seem to notice a difference. So my curiousity arouses me...Driving home at the 30mph limit, I noticed a sort of rattling. I can definitely hear it better when at a light stopped. So when I pulled up to my house and parked it, the noise went away. Put it back into gear, and the rattle noise came back. Put it into Park, and the noise goes away...ANYONE have any idea what it is?I was trying to think about what it could be and I remember something about a ratlle sort of noise from something called the TV cable?Could that be it?
  • Replies 25
  • Views 6.8k
Generally up to about 350 to 400 hp the stock exhaust is just fine. Over 400 hp you would want a 4" system. From what I understand there would be no one on here making enough power to require a 5" system. Even semis have 4" and they make a fair bit more power than we do. If you go to big you can cause the EGTs to climb!! The reason for that is because the exhaust never gets warm and since cooler air is more dense it takes more effort to push it out.
This is good to hear. I need to do the exhaust again and wasn't sure which one to go with.
Mhmm I wish i would of known this before hand. It does have a 4in down pipe till past the transmission so that might help. But man does that 5 Inch make a nice sound!
Okay, so I got my exhaust fixed. I just had the section of the exhaust above the rear-end replaced. I forgot to take a picture of it. My exhaust guy was a little surprised to see it rusting as it was a piece of stainless.Once he replaced that section, the rattle went away! Yay! :hyper:
I bet that does sound good! I like the sound of stacks too, but don't think they will be good for towing my fiver....
It wasn't stainless..... Probably aluminized steel.
Well I ended up in the Big D (Dallas, Texas) last night. Had to park in a parking garage. I set off a total of 16 car alarms while I was in that thing. Its stupid loud and I love it.
