- Replies 4
 - Views 1.4k
								Mopar1973Man 1 post
								gassernomore 1 post
								hd99fxr3 1 post
								02cumminsdude 1 post
I've noticed in my truck and when I had my 5 speed Mustang GT years ago, that when you let off the throttle somewhat suddenly, without pressing the clutch at all, the whole vehicle seems to jolt quickly. Say for example, I pull out and shift normally to 4th gear, then a car cuts me off, and I immediately release the throttle without clutching at all. The whole truck jolts. Doesn't make any clunks or bad sounds. But I was just curious as to what this is and if it does any harm. It gets progressively worse the higher the speed of the truck and RPM's. Usually doesn't do it at lower speeds unless RPM is high. My truck has a fairly new Southbend clutch and the Mustang I referred to had like 30k on it. So it seems unlikely anything is wrong with the vehicle, I was just always curious what exactly was going on and if I should take extra care to avoid it whenever possible.
