- Replies 29
- Views 6k
VectorG 14 posts
flagmanruss 4 posts
white01 3 posts
fire176969 3 posts
Well i think my VP just bit the dust, truck was running just fine i left it running went in a store came out 10 mins later truck wasn't running, It cranked right up idled fine but when i gave it throttle it was not having it exhaust was gurggly and sputtered alot, so i limped it home about 10 miles going maybe 20-30MPH it would clear for maybe 3-5 secs at a time then cut back out.
I got codes
P1693, P1689, P1688,P0252,P0251,P0232 which = VP44 bad.
I checked my fuel filter housing and it was full of fuel and it is still getting plenty of fuel so the Lift pump is good as far as i can tell, is it possible for it still work and the VP be crap? I also cracked the 1st and 3rd injector from the front and cranked the truck i got fuel but not much it sprayed ok but was foamyish. I checked the plugs on my ECM all tight and clean also checked all wires/plugs on the VP and Lift pump. I don't have a FP gauge installed truck is all stock still has the Void sticker on the VP With 285,XXX Miles
Sorry about the long post, I have the money to go get a new VP and lift pump but i'd prefer not to if not needed i hate wasting $$$, I am capable of doing the work myself id just like to have some experienced help, So if there is any one near by who is experienced with taking the VPs off and such or has a fuel pressure gauge and wouldnt mind giving me a hand id greatly appreciate it, I'd help with fuel/Beer your pick haha
Thanks in advance
