Proper Bolt Installation Guide..??
- Replies 9
- Views 4.3k
Mopar1973Man 2 posts
ISX 2 posts
diesel4life 2 posts
pepsi71ocean 1 post
The other day I had a member call me asking about loctite and such and although everyone has their own way of doing it, I thought it would really be neat to get a guide going as to when to use loctite, what type to use, fine vs. course. thread benefits, wire wheeling the bolts before reinstalling, what you should do to the hole before putting the bolt back in or just on a new install (new part install). Also the importance of proper bolt torque and what tolerances there are (how close to the spec does it need to be..) For instance, the red and blue loctite seem to mix together in applications if you ask me. I was thinking we could get some solid guidelines to which one to use for what application.. Then there is what to do with a bolt that you take out and put back in.. I know some people take it out and put loctite over the old loctite and stick it right back in. Then some people don't use loctite at all. Then there are people who clean the threads up with a wire brush and stick it back in with or without loctite. Then there might even be some people who never reuse old bolts. Then there are custom installations that may need to be tapped, so do you use course or fine thread? I realize the physical differences and strength differences. Fine thread is stronger but then why do we have course thread.. Then we have the bolt, we can use a new one, polish the old one, don't polish it,..but what about the hole? Is it necessary to run a tap down it to clean out any other residue? Then we have bolt torque...I know a lot of people say to overtighten things so they don't loosen or slip in the case of my timing gear which is timed and held there by just the pressure of the nut, no keyway. So is there some % tolerance for the torque values? I will be definitely turning this into an article.. My personal input is to wire wheel the old bolts, put loctite on them, and reruse them. I don't touch the hole unless the screw has issues going in which then I run a tap through it. I don't see any reason for course threads other than how quickly you can unscrew them. The proper bolt torque tolerance is unknown to me. Those are my rough thoughts. I'd really like to get in depth on this with you guys. If there are alternatives to what I just said, alternatives to loctite, by all means share your thoughts.
