New member, lift pump questions.
- Replies 9
- Views 2.9k
dobienut 3 posts
diesel4life 1 post
24Vdodge 1 post
snowshoveler 1 post
Hello, new member, 1st post. Long time dodge CTD owner. Have lurked on many of the Diesel forums but never joined one. This one seems more laid back and relaxed then some I read info on.
I just picked up my 3rd 24v 2nd gen truck a few weeks ago. It's a stone stock 98.5 24v, just had a reman IP pump put on it less then 4,000 miles before I bought it. I bought a 1999 brand new in the fall of 1998, I could write a novel about that trucks healthy appetite for lift & IP pumps and my experiences with cummins and dodge about it. But that is not a new story. No one had an aftermarket fix for those trucks back in the day when they were brand new, like a AD/Fass. I sold my 1999 when it was less then two years old B/C of the problems and went back to driving my old dependable roughing riding 1st gen dodge CTD.
Fast forward to 2007. I caught wind of Fass/AD systems as a good fix for 2nd gen 24v trucks and did lots of reading on the subject. I was longing to get back into the cushy seats and smooth ride of a 2nd gen after a few hundred thousand more miles in my old 1st gen. I found a good deal on a 2000 that just had a new IP put on it, I put a AD 100 on the truck the day I bought it. Other than the perpendicular bracket that broke twice, right at the weld (to much deflection IMO) I had no complaints about the AD 100. They sent me the bracket that runs the pump parallel to the frame and was a lot more solid and never had the problem again. Truck always had good fuel pressure and never had one fuel issue with the pump. I owned that 2000 for 4 years and put just over 200,000 trouble free miles on it thanks to the AD 100.
The 1998.5 I just picked up, I was originally going to put another AD 100 or maybe the 165 (kind of like the regulator idea) on it and be done with it. I put a fuel pressure gauge on the truck and it has just over 13 lbs @ idle and gets down to 9-10 ish when you stand on it. Something needs to be done soon. I have been reading about a lot of problems with the AD's now and since a change in ownership the quality has gone down hill. It does not sound like they are what they once were back in 2007 when I put the AD 100 on my 2000.
I came across a thread pertaining to Glacier Diesel Fuel Boss belt driven mechanical pump. They have me very intrigued. I've read several threads about them, don't really see any cons about them, seems to be only pros. The only thing that concerns me is where they are mounted. I live on a gravel road and do quite a bit of gravel back road driving. I'm kind of concerned that dirt or debris might get up in there and chew up the belt. Maybe there is some type of shield that could be built from an old heavy rubber mud flap to lessen the chances of damage from stones and dirt? That is really my only concern about the pump. I sometimes go on long road trips and get to far away places where there is no cell phone reception. I don't want to have a breakdown, been there, did that when I had my 1999 one to many times. I always had faith in my AirDog and was 100 percent comfortable going anywhere, but my faith is now wavering.
I do like the lifetime warranty on the AD vs the warranty on the Fuel Boss. But I dont want to messing with replacements on the AD if/when it goes down either even if they are covered under warranty. I only want to buy one lift pump system, I am really leaning towards the Fuel Boss right now.
Long story short, what would you recommend? The Fuel Boss or the AirDog for reliability and longevity? I pretty much keep my trucks stone stock, and like to put miles on them. I like to either put on a 4" exhaust or a straight pipe stock exhaust. My last truck had a Icebox cold air intake but with this one I am going to do the BHAF. Sounds like the Fuel Boss can keep up with the fuel demands of either stock or mild to wild. So I guess it doesn't really matter if I want to bomb the truck out or not. I'd be very interested to hear your thoughts and opinions. Thank you for your time.
Matt
