Voltage surge at cold idle
- Replies 5
- Views 2.4k
NWMontanaMan 2 posts
Mopar1973Man 1 post
ISX 1 post
AH64ID 1 post
I replaced my alternator and belt recently and since then I've noticed a weird voltage issue when I start up the truck first thing in the morning. When I first turn on the key voltage comes up to 12V. As the engine cranks it drops momentarily to 8.5-10V, then when the engine is running voltage returns to about 11.5V. It stays there for 10-15 seconds until then the alternator pulls it up to 14V. Then the voltage (and the engine to a lesser extent) starts surging between 12.5 and 14V. This continues for a couple minutes and then things even out where they should be (about 14.5V).I'm confused!
