bigger turbo
thinking about going bigger what are the pros and cons looking for that extra kick have a fass platinum fuel pump bhaf 4inch exhaust rv 275s edge comp not unlocked yet decent tranny and friend that owns a tranny shop
  • Replies 6
  • Views 2.5k
Just depends on how much money you want to spend, and how much HP you want.Do you tow, sled pull, race, or DD?
You can get into an HX35/40 hybrid for pretty cheap and it will add air and boost to your rig.I have this on my 2000 with auto trans and RV275s and I can spin the tires from a dead stop launch with no use of the brakes to spool the turbo.Couldn't do that in stock format ever.
I wouldn't go bigger than a hybrid HX35 of some sort or form with your setup unless you plan on bigger injectors.
thanks for the replys guys no its just a daily driver thinking about unlocking the comp box and maybe a new exhaust manifold and intake with a new elbow
x2 Turbo will do very little for you with those injectors/fueling.
