- Replies 14
- Views 4.3k
War Eagle 6 posts
dorkweed 2 posts
rancherman 2 posts
pepe 1 post
I have air adjustable shocks (Rancho 9000XL) and have a small air compressor and control panel used to adjust the shocks at will. This little compressor doesn't put out much air and can't really be used for any other function.I am considering setting up on-board air (compressor and tank with necessary controls) so that I have enough volume and pressure to run of few more accessories (air horn, exhaust brake) and have the ability to air up tires, float tubes and/or do any other general maintenance things that I might need while out in the field.I have been doing some research on what kinds of 12v compressors are used in these kinds of situations and I am finding more options than I expected. Seems like there is no shortage of 12v compressors and they come with varying duty cycles, varying volume and pressure capacities. Seems some take a long long time (i.e. 30 minutes) to air of tires, some get really hot when working hard and some blow circuit breakers often.I see names like Vair, Extreme Air, Q-Industries, Pittsburg (Harbor Freight ), ARB, Smittybuilt etc.I've seen prices for compressors alone run from $59 to over $400.I am interested in knowing if anyone on this forum has installed on board air and what you have used and why you made that choice. Where did you install your equipment and did you have to do anything to protect it from the road water and grime?I am currently thinking that I need something capable of 4-5cfm and pressure capability to 120psi and a receiver of 5gal or so. But in relaity I have no experience nor do I have any source that can provide me with some practical user knowledge.Any practical insight would be greatly appreciated.
