Engine Efficiency/fuel rate/etc. calc
- Replies 11
- Views 2.4k
AH64ID 6 posts
ISX 2 posts
Wild and Free 1 post
CSM 1 post
I think you guys might find this neat. Basically you enter all but the g/kWh initially, based on your data plate. For instance, my engine says 215hp, 2600RPM, 103mm3... The spreadsheet is saved with my specs so you can see where they are. The fuel density should be left alone as thats the average density of diesel fuel, though I have it unlocked if you happen to know something about your fuel that I don't. You can see it calculates the g/kWh...This is the engine efficiency! Once you know it, copy 3 or 4 decimal places worth into the cell next to it. Once that is done, you can mess with all the rest and treat the g/kWh and fuel density as static variables. I added the MPG and MPH for the heck of it so you can see what you would be getting. There isn't much error checking on this as I'm busy with other crap so just use a little common sense as in don't leave more than one variable blank and don't fill them all in. I'll try and build it in later. If you are just wanting to mess with it (without looking at your data plate) just put 250 in for g/kWh as that is about the average of all the trucks. Oh and password to unlock is dodge as usual.
Engine Efficiency.xls
