- Replies 9
- Views 4.1k
ISX 3 posts
cajflynn 2 posts
AH64ID 2 posts
98whitelightnin 2 posts
I found this pdf by garrett and although our turbos aren't water cooled, it does teach you a lot. http://www.turbobygarrett.com/turbobygarrett/sites/default/files/Garrett_White_Paper_01_Water_Cooling.pdf
On the 5th to last page they show an oil slinger groove, one that was fine and one that was overheated. Mine looked just like the overheated one yet this was before I had ever ran over 35psi. Before I had it, it was a completely stock hotshotter truck. I always let it idle a long time if I had ran it hard and turned it off at 300F.
Soo...what gives! What do you guys think caused it? Is 35psi actually too much for an HX35? We know they are all wastegated to 20ish so 35 is pretty far past that..
Also found this, kinda interesting. http://www.dieselpowermag.com/tech/dodge/1209dp_the_worlds_biggest_turbo_test/viewall.html
Here's pics of the original shaft I took out (before the mill had its way with it lol)
