Front Steering/Suspension - advice needed
- Replies 10
- Views 4.1k
CUMMINSDIESELPWR 3 posts
98whitelightnin 2 posts
Wild and Free 1 post
Burton85 1 post
Hello. Looking to tighten up the front end on my 01' with 225k due to steering wheel play and a little slop. Question I have, do you guys recommend replacing the pitman arm, tie rod, steering damper, track bar, control arms, etc or should I just replace the bushings and any worn out parts? Trying to not break the bank but at the same time I dont want to end up doing the work only to find all new parts were a better route for this repair...Thanks!
