My headlights aren't quite cutting it for me anymore. I had a similar issue with my 2000 V10's headlights, they just don't put out much light. Our 05 Silverado low beams are equivilent to my trucks high beams, especially in the rain. I am planning on picking up some "smoked" housings to go along with my all black and white color scheme. I was wondering if the brightness problems lie solely on the bulbs used, or will an aftermarket light put out much better brightness? Link to kit I am looking at: http://www.ebay.com/itm/94-01-DODGE-RAM-SMOKED-LENS-HEADLIGHTS-LAMP-ASSEMBLY-96-/220806310939 If it is a bulb issue alone, I have no problem buying this kit and then swapping some more powerful lights into them right away if that's possible. Thanks for any help.
  • Replies 41
  • Views 27.2k
From what I have noticed, there are 2 different Sport models of trucks. Pre quad cab, Those are all painted the monochormatic but share the same bumper and headlights. The quadcab sports have the different bumper, grill and the 4 bulb headlights. Main thing on the truck is pre 98 or 97 the rad support will have to be opened up to accept the 4 bulbs units. Mine is an 01 so the opening was already there as it was probably easier to have one rad support.
https://www.dropbox.com/sh/02data1uuqsa7wd/pkpQW7sr4x#f:IMG_3201.JPG https://www.dropbox.com/sh/02data1uuqsa7wd/pkpQW7sr4x#f:IMG_3206.JPG these links seem to have a habit of expiring. the housings are available in black or chrome. ebay item. I've had two sets, the halo power supplies don't seem to last, one failed on each set after a couple months.
Thanks for the pics! After the Halo power supplies went out what did you do? Ho wis the lighting? Easy to adjust? I think those are the ones I want. Link to get them? Model number or company?
I ordered the harness from Daniel stern today. I ordered my grandpa one on Monday and he said it arrived today before his sport lights.
I saw a post the other day... A guy bought some morimoto mini projector kit... Disassembled the headlight unit drilled a bit cut a bit and made some kick a$$ headlights... Pictures showed amazing lighting and didn't have that ricer bling led ... Also I imagine with much more reliability since morímoto projectors are quality... Used a clear headlight unit though sent from my cell...
Ignored the halos not lighting. Light was more than great. Not easy to adjust or change bulbs though. To be expected with aftermarket lights really. Retrofits (re:minimoto) must be done with a clear lens light, and are a lot of work to fit properly.
Whats the difference between the Stern harness and the one Rogan published the .pdf on?
I think I posted these pics up somewhere but Ill throw them out there again. I found a guy that makes the harnessess as well, great quality. I have heard nothing but good about Sterns stuff other than the fact he can be hard to get a hold of, this could be a viable alternative for anybody looking. Took about a week to 10 days max to get the harness.post-11861-138698200168_thumb.jpgpost-11861-138698200177_thumb.jpg
I ordered my grandpa a harness from Stern on Monday and it arrived to him Thursday so I hope mine is here mid week.
Daylight driving lights ( DRL) found on all canada trucks post 1980 something. The High beam has 6V when truck is running, lights off.
I personally don't have them and have never seen them on a 2nd gen.
Me either. Is it just a Canadian thing? Sent from my SPH-L710 using Tapatalk 2
I don't have DRL either. I ordered my Stern harness on april 11 and it has not made it yet. I am gonna send him an email cancelling the order.:doh:
Let me know if you need another source. I ordered one from a guy that builds them out of his garage. Good quality, fair price, and I had the harness in my hands in less than 2 weeks. I'm just using old bulbs (not the recommended ones) and wow! What a difference. Should have done this years ago.
I bought the same lights you had, I installed em and they looked great till I turned em off. The passenger side halos stayed on even with the lights off. I rewired to make sure everything was right, same outcome. Turned out that the halo housing was shorted to power so they were lit 24/7. Worst lights Ive ever bought and never will I buy them again nor would I recommend them to anyone, lol. Sport conversion sounds like the way to go! :thumbup2:
That sounds.... Interesting. Considering the housings are plastic I don't see how anything could short out aside from in the harness - and where was constant power even accessible to short to? I hate to say it but that really sounds like a truck side wiring problem. Tapatalking in traffic
The housing around the halo and high/low beams have metal contacts and rings in em. A guy I woek with is a 12v guru and I had him tear em apart to find out why they are staying on, that's the verdict he came back to me with. :shrug:Not sure why but now the halos are burnt out. When I bought my truck it had the same lights in it, halos and the led lights were all out. plus the lens's were sun damaged so I replaced em, not a fan at all.
I was thinkin' the same thing..
12v guru, huh? :think: Lights off = zero voltage to headlights, period. But, yeah, the halos seem to be the first thing to take a crap on the ebay lights.
