update on vp install... wierd noises now apparent.
- Replies 11
- Views 2.2k
CUMMINSDIESELPWR 3 posts
diesel4life 2 posts
rancherman 2 posts
CSM 1 post
Finally got the vp44 plumbed, primed, bled, and wired. As my son was cranking the engine to bleed the hp lines, I got this psssh, psssh, pssssh noise....
Now, I'll let you know what isn't done yet on this 'several fixes at once'
Intake is still open to the world. Air horn is not there, along with any form of intake pipe or turbo.
Radiator is not in,
steering gear is not in, Lines are dangling from the pump. I did allow the engine to 'fire' for a couple seconds after tightening the hp lines....just to confirm my 'new' pump is a runner... and that part is good.
Back to the weird noise: I would swear the noise is coming out the intake plenum... At least that side of the engine and/or front of engine. It's definitely equal spaced... Like 1 phssssh per 2 revolutions. My thought was at first; bad or out of adjustment intake valve, and without the air horn in place, I can now hear it.
Or another scenario: I got a bad spot on my vacuum pump seal, and since I didn't allow the engine to start, I could hear it leaking? there was noticable blowby on just cranking speed. (it was clear clean air since the engine wasn't actually running) I only noticed it because I put my thumb over the tube. It took about 5 seconds to feel the pressure (slight, but still there... I'd guess 1-2 #s) It was a smooth flow... no puff puff puff..
Or... and I am being really hopeful on this... it's the way one injector line could be 'resounding' on the sheetmetal lid of the intake..
Truck has 135k miles, and I'll run the valves tomorrow..
Anyone care to jump in here?
Thanks!
- - - Updated - - -
.....ran the valves this morning... most were a tad loose. No tight ones.
hooked up the air horn and downpipe-to-the cooler and refired the engine. I can hear the phssssh through the intake tube.
Head gasket.
