hard starting with fuel pressure
- Replies 9
- Views 2.3k
2500ctd 4 posts
CUMMINSDIESELPWR 2 posts
Mopar1973Man 1 post
diesel4life 1 post
Ok found out my truck is actually having a hard time starting with fuel pressure showing on the gauge. Never had this issue before and dont know how long its been going on.I have remote start and almost always use it.
Until my truck gets to slightly under 1/4 tank. I have a bad cut DS so at times under 1/4 tank it will start then stall or not start till I prime the fuel system with the key bump trick. Well last 1/4 tank I remote started it watching the gauge. Started up as normal but seemed to take a bit longer to get FP up. Ok I says. No more remote starts till fill up. Next day I prime the fuel system first, it cranks a couple seconds then starts.
Let it idle a bit shut off and restart with priming, fires right up. Repeat with priming more cranking.Now IIRC a torn or cracked diaphragm will cause this correct? The articles IIRC mention it being a problem when hot. This was first fire of the day.Reason is I am starting to suspect a tired VP44. Fuel economy isnt what it was, wife noticed a different idle, which now that I think about it it does. I did advance the timing on the smarty to level 4 recently and it started the stalling going into gear thing...again. So we decided to start a VP44 nestegg for when it goes. Just wondering if this new hard starting is another hit against a tired/worn out VP. Truck drives fine, has power and no trouble starting cold or hot, as long as I dont pre prime the fuel system.
