- Replies 16
- Views 25.6k
CUMMINSDIESELPWR 6 posts
Mopar1973Man 3 posts
dripley 3 posts
Purplppleter 3 posts
hey all, got an 02 dodge ram 2500 that the only way i can get to fire up is to break #1 and 3 injector lines loose. The truck will then crank, run about 10-15 sec and die.. Lil history, truck died while driving it , the pick up pump was replaced(not by me) and brought to me with the problem it has now.. I checked voltage at the pump and have 12 volts, checked it as the truck dies and no voltage loss.. Checked the fuel pressure at the injector pump. Fuel pressure is 12 psi and also does not drop as the truck starts to die.. Found code p0216, found your vp44 trouble shooting articlefollowed it to the wire jump and by it the injector pump was bad.. replace pump, truck still does the same thing. Talked to another tech that said it sounded like the an injector was hanging open. So i pulled the injectors out and had them tested. 2 injectors were found to be bad and 3 of them were weak.. Replaced all six injectors, yet still same problem. Seams its running out of fuel between the injector pump and injectors.. There are no inactive or active codes when a reader is hooked to it, but when i cycle the key 3 times it shows p ecu 0230 (injector pump voltage if i remember right) unhook the batteries for 20 mins or so to reset the code.. code is still there when batteries are hooked back up, but obd2 still shows no codes..
