The C.A.T. is outta the bag!
- Replies 13
- Views 3.4k
dripley 4 posts
diesel4life 3 posts
Mopar1973Man 2 posts
pepsi71ocean 2 posts
On the way home, trailered the 5th wheel. Had a few CAT scales I was going to pass so decided to stop at one at the LOVES gas station.Got the truck/trailer weighed. Me, wife and dogs with some extra stuff that we packed for the over night drive to pick our trailer up from family's house. Black tank is about 1/2 full. So that weight is incorporated too. Black tank is in front of axles. Was gonna dump, but my sewer solution kit did not come as it should have...So here are the numbers, someone help me make sense?!Truck, trailer together:Steer axle: 4340 lbs.Drive Axle: 6360 lbs.Trailer axles: 10120 lbs.Gross weight: 20820 lbs.JUST trailer on scale:Front jacks: 4580 lbs.Rear axles: 8800 lbs.Gross weight: 13380 lbs.JUST truck(Just me in it when I did it and no superglide hitch):Front: 4190 lbs.Rear: 2660 lbs.Gross: 6880 lbs.Okay, so can someone help make some sense of this for me? The biggest question I have:The trailer being weighed by itself, the front jacks on one part of the scale; 4580 lbs? :ahhh:That can't be accurate for pin weight, right? Cause when its hitched to the truck the math would not work out..If that really is pin weight, then keystone has LIED big time! Cause in brochure it says hitch weight is 3090 lbs. That would be a big screw up on their part for not properly weighing it. But I dunno how to exactly calculate pin weight. Except for rear axle weight on truck, before and after hitching...Man, did I mention $10 to weigh?! $2 to do a reweigh...
