Under Water any hope?
- Replies 12
- Views 4.8k
hex0rz 3 posts
flagmanruss 2 posts
CUMMINSDIESELPWR 2 posts
GreenRiverCummins 2 posts
Just as the title say's my boss took out the work truck a 1997 dodge 3500 4x4 5spd. Down to the river after work 2 week's ago it had been raining for day's and has rained almost every day since. Needless to say due to mostly an inabilty to drive a dually on wet ground and laziness. We seen today that the truck had water almost over the cab!!!! So without a doubt the truck is totaled now and should it still stay put and not get washed away in the flood. I have requested to get first dib's on the truck to buy the truck back from the ins company. so i guess my question is how much damage should i expect. I have rebuilt many wrecked vehcile's and i know to stay away from salt water flood truck. But i figure the truck will only be under water for about 2 day's of fresh water. Givin' the truck is a 12 valve and has little electronic's. What are the odd's the truck as a whole other then the good body part's could be saved? the body was perfect had no dent's nearly no ding's or scratch's. And the truck had 69,xxx original mile's!!! I felt sick when i heard that due to laziness the truck could be destroyed now. But i pray the truck stay's strong and dosen't float away. I know that i have to let the truck dry out for a few day's and drain all the fluid's out of everything and go through everything with a fine tooth comb but at this point all i can do is sit and pray she can hold her ground.
