New injectors, now VP shows weakness...
- Replies 18
- Views 3.2k
Mopar1973Man 8 posts
MassRattleWagon 6 posts
CUMMINSDIESELPWR 2 posts
Yankneck696 1 post
Hey guys, ill try to keep this short. I got some 7x.009 dfi injectors last month. After installing these, my truck has a rough idle when engine temps are hot. I had these sent to chris at dfi and the injectors are all pop tested and flow at 300 bar. My install was good all new orings and copper washers no scoring on crossover tubes When i had my stock injectors in i had no rough idle at all, no hard starts, and no fuel leaks. Truck has had raptor 150 since ive owned it 19 psi idle 15-16 wide open. No check engine lights since ive owned the truck. But when i bought truck last september it has 8psi idle with factory pumpWhich is now leading me to believe that because im forcing more fuel at idle at the VP its showing a sign that it might be tuckering out???also its a reman vp on the truck now and i have no clue on the miles. I guess my question is are these injectors showing me my VP is shot or i missing some high pressure leak in fuel lines. Sucking air so to speak. At idle with these installed it feels as if i have a line cracked open at head, but if i reinstall stock injectors idle miss goes away...let me know what ya think. And i appreciate any input gary
