- Replies 9
- Views 2.1k
Lone Watie 4 posts
Mopar1973Man 2 posts
flagmanruss 1 post
98whitelightnin 1 post
This will be a little difficult to describe. When I first get the truck rolling in the morning, I'm hearing a rubbing sound which sounds somewhat rotational, in that it is not constant. It seems to be coming left front. It started a few weeks ago after I changed my crankshaft position sensor, where the only thing I had done was remove the started and reinstall. I have not lifted front end up yet to check wheels, but this noise stops after a few hundred feet, and seems to be only when the truck is not warmed up. If you have any tips please let me know so I can start checking into some things. The starter is brand new rebuild as of yesterday (warrantied one went out yesterday), and it's in there securely.Here's a little history:1. In Feb of this year I changed my starter2. Back in end of July, I replaced my crankshaft position sensor, and had to remove starter again3. This past weekend my starter went out at the store (had her towed home to fix)This sound is not so much a rubbing but a rumbling sound and like I said, it's not continuous but like there's one spot it's rubbing as I roll and then it stops (I think) after a few hundred feet, and doesn't do it again until the truck is cooled off. I was concerned it was the starter mechanism not retracting fully and rubbing the flywheel, and then retracting, but with having to replace a starter (which may have just been an auto zone dud) again this past weekend made me focus on the starter. I'll have to lift the front up a bit to roll the wheels around to check out if it's coming from the wheels to rule that out, but as I mentioned this all started when I replaced the crank sensor a few weeks ago. Any ideas?
