Over filling 6 Speed tranny
So in the efftot to elimanate issue's in my tranny before I put on my Master/Slave Clyinder. I took the time today to check the fluid level on the side which seemed almost full. then i took off the shifter and what level should the fluid be at cause it looked about 10 quart's low lol Cause i could see way down there is it suppose to be all the way up to the shifter base?? Cause I have no idea i put a quart in it and i couldn't even tell i had put any in it. So any info would be great
  • Replies 21
  • Views 7.4k
I get the noise in 4th more so than any other gear(1200 to 1400 rpm) and not in neutral. But I have a Valair and not the OFE. I dont know how different they are.
