Dash vents not working, A/C blows to the foot vents only
- Replies 5
- Views 11k
flagmanruss 1 post
FlatTwin 1 post
CTcummins24V 1 post
mopartechnician 1 post
Have not driven the truck in a bit (wonderful VP-44 puked again and no $$ to fix it!) but jumped in the truck over the weekend to move some big stuff around and when I turned the A/C on it worked fine but would only blow air out of the foot vents.No matter what position the climate control switch was in, air came out of the lower vents.Searching the bulletin board I did not find anything like this but did find several threads about the vent system being controlled by vacuum and if you had a leak that the doors would default to the floor vents. Any hints or suggestions on this? Thx,FT
