Ranting and a transmission that doesn't know what it wants
- Replies 18
- Views 4.1k
Racer Dan 8 posts
Wild and Free 6 posts
guesswho512 2 posts
Mopar1973Man 1 post
I have a 2002 CTD automatic that can't seem to decide what gear that it wants to be in or if it wants the convertor locked or unlocked between 35-40 MPH... Maybe the apps is bad? I remember when the auto manufacturers made stuff that was pretty good. They made cars that didn't blow head gaskets, didn't wear out wheel bearings, etc. GM had Turbo 400 transmissions, Turbo 350's weren't too bad either. Ford had c4 and c6 transmissions that performed quite well and the famous 9" rear end that is still the standard of many racing series to this day. Chrysler had the 727 and 904 transmissions and also the Hemi 4 speeds that were very good. Also the 8 3/4 rear ends as well as the Dana 60 used in many vehicles was durable. The 833 trans was also very durable. The slant 6 Chrysler engine was also very good. Then came the mid 70's and alot of "advancements in technology" came along which I think were disasters in some cases. Lean burn ignition systems coupled with lock up torque convertors, carburetors with tamper proof idle adjustments, light duty differentials with spider gears that failed, front wheel drive cars that blow head gaskets and wipe out cv joints all of the time, automatic transmissions that don't have adjustable linkage shift points like the old ones did so a guy can adjust it to suit his own driving style, lease cars that are designed to last 3 years, lift pumps with inferior parts known to fail and not re-engineered to perform and last, aftermarket wheel bearings that will collapse within a year, rotors that are made on a minimum so once they warp they are scrap, door handles that break and door hinges that wear out rapidly, manual transmissions that don't work properly, etc... For the money that we spend to buy these vehicles we shouldn't need "forums" on the internet to make and keep the things running. It's rediculous really.:confused: I'm just pissed off because all of these automatic transmissions these days aren't worth anything.I have rebuilt 727's and 904's in the past and they were very easy and cheap to do. I can't wait to take apart one of these "new modern" trans and see what they have in them.
Edited by Racer Dan
