- Replies 10
- Views 2.2k
IBMobile 2 posts
diesel4life 2 posts
24Vdodge 2 posts
Mopar1973Man 1 post
I have a exhaust question. I bought a MBRP 4" system for my truck in my Sig, back in May of this year. I am just now getting around to putting in on today. I put everything on and it went to pretty fast. Before I tightened down the clamps and hangers, I wanted to check the firewall to down pipe clearance, to see if it needed to be moved or pivoted. There is a 1/8" at best. Here are three pics of the down pipe. The two from the top look like it is sitting right up against the firewall pad, but when you look at it from from a different angle like in the 3rd pic you can see there is a "LITTLE" bit of clearance, about a 1/8" at best.
I put a MBRP on my last truck (6/7 years ago) and I remember it had a lot more firewall clearance than this. If I recall correctly it had at least an inch, or better. What do you guys have for clearance? I took the long straight section under the cab floor off the truck, and pivoted the down pipe so it had more clearance at the firewall pad. This moves the end of the down pipe away from the firewall pad insulation. But with the exit part of the down pipe pivoted, it no longer lines up with the rear portion of the exhaust. It is off by 3 to 3-1/2" from lining up.I fooled around with it some more. It seems like the mount that is welded to the down pipe, where it slides into the transmission mount, is either too long or it is welded in the wrong place on the pipe. 2 questions 1, I am wondering what you guys have for clearance between the down pipe and the firewall pad for those of you running a 4" exhaust? 2, Has anyone else running a 4" exhaust run into this problem? I dont want to start my truck on fire and I am not comfortable with a 1/8" of clearance.Thanks!
