South Bend Clutch's?
- Replies 11
- Views 5.5k
dorkweed 3 posts
CumminStrong 3 posts
AH64ID 1 post
mopartechnician 1 post
Hello,So it may be time soon to replace my 180K stock clutch. I just replaced master and slave hydraulics. This is on a 03 2500 with NV5600. I have been looking at SB as my replacement. Here is a question from those that have run them and what they experienced. I tow about 10k - 19K during the summer with a dump trailer, hauling large 8x4 hay bales and equipment. The stock as done just fine during all this hauling but I dont try to drive it like it was not loaded either. The rest of the year/winter, I use it as a daily driver to work and back home. Wife drives the rig so I need something that is not hard on the knee or engages aggressively either. Want to still drive off in 2nd without major shakes and backup a good load without the whole "use low gear" idea. The only major power upgrade is a Smarty running at #7 for fuel milage, not romping around. Rest stock.Here are the choices: 1947-OK-HD or 1947-OFEK Appreciate the advice in advance.Jeremy
