AC noise/torque lock up issue problems
- Replies 29
- Views 5.6k
kedlin88 10 posts
Mopar1973Man 4 posts
JAG1 4 posts
diesel4life 4 posts
Ok, first off I bought this truck about 1.5 months ago and before I bought it, it had two brand new batteries and a brand new alternator installed. To be honest when I test drove it I don't believe the TC ever locked up(didn't know what TC lockup was when I bought it.) The transmission fluid was real brown and smelt really burnt, so I dropped the pan and changed the fluid and filter and adjusted bands(about 6 qts is all i got changed out. I didn't do I complete flush.) So now when the truck is cold, the TC will lock up at about 45-55mph, and the transmission starts to shudder until I get up to speed. After I get on the hwy it will stay locked in for about 4-5 miles then it starts to unlock and lock a couple of times till it finally stays unlocked and wont relock the rest of the drive into work. So I think I am starting to have the a/c noise issues. I first checked the codes and I get no codes. When I got home I checked the DC voltage at the battery and get 14.3 or so. I then switched my meter to ACVs and it reads 30.8???? I believe I have the meter set right for AC but not sure. I included a picture with the setting to make sure its right. I then remove the alternator fuse and check again on ACVs and it drops down to 26.3?? Are these readings right? When I check the ACVs at the fuse I get nothing, I just get the readings at the battery??
- - - Updated - - -
I'm not sure if my volt meter is on a low enough setting for the ACVs. I also don't know if the fluid change had something to do with it? Fluid is burnt and brown in color. Then I replace 6 qts of new fluid and it starts this? Maybe it needs a complete flush?
- - - Updated - - -
Im not sure if this had anything to do with my bad gas mileage also. I got 12.5 mpg when I bought the truck completely stock. Then I added 4" straight pipe and a BHAF and I have ran two tanks and it only brought it up to 13mpg.
- - - Updated - - -
Alrighty, I removed the alt fuse again and took for a test drive. And still the same, not locking up on the hwy. Also, when I removed the alt fuse, my airdog 150 ran all the time??
